Pyronix Query
25 Jun 2019
Hi
1-Does the Pyronix enforcer V10 panel work successfully with Fob's without using KEYPAD, Any CONS of not having Keypad ?
2-Do you recommend wifi Siren Pyronix or you recommend Wired Siren with rest of system being wireless?
3-Can we run Wifi module and GSM/GPRS module simultaneously. Is it possible that system run on WIFI by default and in case of BT line cut system auto switch to GSM module in realtime.
4- Does system work perfect on GSM module? Does ProControl+ app run perfect with GSM module only without WIFI module?
5- What will be the annual cost of world SIM after first year?
6- If GSM module is not used Do you recommend CSL miniair with wifi module to get notification of BT line cut ?
Regards
The enforcer has a built in keypad so not sure what you mean.
Pyronix do a wireless siren not a wifi siren, hard wired always best if possible.
Clarifying some of these points with Pyronix, but it would appear its not possible to achieve wifi and gprs back up.
The GPRS wouldn't help if you had cameras on pro control as they are not routed through the panel.
However what your asking is possible on the Risco Agility panels, to the point you can have voice, gprs, sms running from a gsm module subject to signal strength, you can also have an ip module for the app connection and switch to gprs if the ip connection fails, allowing a payasyou go sim like giffgaff to be used, so that data charged when used only, same as voice and sms. Installed a few Agility panels that way.
confirmed the gprs module can do the gprs fo the app and SMS, but only with your own sim.
