Pyronix questions
28 Dec 2018
Hello all, a few quick questions.
Current configuration is -
PIR upstairs
PIR downstairs (exit route)
Door contact back door (final exit)
The system was installed by my electrician and I have access to the engineer mode.
1. Can I stop the control panel beeping when buttons are pressed - My dog howls when I am trying to adjust the system so it would be much easier if I could disable them when in engineer mode.
2. I am going to add another contact to the front door - Can that be final exit too?
3. My downstairs PIR seems to be permanently on whenever I walk past the blue light comes on. From reading other posts this does not sound right - Are there settings for that in the control panel? The PIR upstairs behaves as I would expect.
Thanks in advance!
Perfect, thanks! - I will have a look tonight. Once I have got the keys volume down I will be able to work on it a lot easier.
A couple more questions though...
With the deltabell-we how much would having the comfort LEDs on affect the battery life?
Also I understand that engineer mode does not stop the sounder going off if I open up the bell (to change the jumper) is that right??
Two options drill up to loft and fit psu or buy a haydon flashing led unit , runs off a CR123A battery and will fit inside the delta bell
Wireless keypad and extra PIR fitted. key tones turned off so less of a howling dog! Flashing units ordered - Will fit the extra bell next weekend.
Such a shame that insite is installer only - Would have made my life a lot easier...
