Pyronix Sterling 10 alarm – changing telephone contact numbers
29 Jan 2019
First time poster, I really hope someone can help…
I recently moved into a house with a Pyronix Sterling 10 home alarm system. It was installed a few years ago and is in fully working order.
However, it still has the previous owners telephone contact numbers programmed into it (the numbers the alarm calls when it goes off).
I’ve been through all of the menus and I can’t find a way to change them. I’ve phoned the installers and they’ve said they can do it, but they’ll charge me £100 for a call out.
I’m reluctant to pay £100, and have to wait in all day, for what undoubtedly is something that’ll take a few minutes and I could do myself (if I knew how!).
Can anyone help?
Thanks in advance.
Sterling 10 panels don't dial .
There will be a aftermarket device fitted to your alarm
E.g. Menvier sd1, pyronix vocaliser , texecom speech dialer
Thank you for the reply. That makes sense, and I do indeed have a Menvier SD1 unit too.
I’ve found the instruction manual online, and it includes how to change the telephone numbers. However the first step is to ‘key in the current passcode’. Will that be the same current passcode as the actual alarm itself (I changed it when I moved in to the house) or is it totally independent?
Luckily the previous owners had written the code (they’d chosen the same as the original alarm code I think) down in the various paperwork they left with the house, so I gave it a go last night. I haven’t changed the phone numbers yet, but I can get into the menu to do it… so it looks like the issue is resolved.
Thank you to those who replied, I knew it would probably be a simple fix, but without your assistance I probably wouldn’t have known how to do it. Your help is much appreciated.
