Hello All
Really grateful if someone could help me out.
I’ve bought the Sterling 10 Alarm system, 2 LCD RKPs, Door Contacts, Belle, and 4 PIRs. I’ve been installing piecemeal other the past few evenings.
After the electrics and control box were installed I connected the first RKP and tested my connection. The system booted and the RKP sounded it’s internal alarm, and displayed a ‘system armed’ message. I couldn’t enter anything on the keypad despite the keys beeping as I pressed them. I assumed this was due to the wiring not being completed.
Next night I installed a PIR and the door contact. Tested again, and same as before, with the keypad alarm, message and keys. Still didn’t worry as knew I had not finished wiring.
Cut along story short, I finished the wiring tonight, linked out unused zones and PA and hoped all would be well. (Incidentally I have not connected the battery yet).
When I switch on now, the keypads are alarming, with the ‘System Armed’ message, the belle is sounding and PIR lights are permanently lit.
Well you know my question…What do you think is or what have I done wrong? I’m pretty sure the wiring is correct. But is there something I may have overlooked? I have disconnected each component at a time to try to isolate a wiring problem but regardless of what’s not connected I get the same thing.
The manual doesn’t say “When you first power up you should see x, y, z etc” so I am at a loss as to what to expect and do.
Before I have to admit defeat and call out a pro-installer to finish the job, is there anyone that can offer some advice.
Many thanks in advance.
