- Joined
- 17 Jul 2018
- Messages
- 413
- Reaction score
- 34
- Country
Hi all,
Hopefully I'll explain this well enough...
I have a tag user on my panel set as follows
User Type (0)
User Areas (C)
User Set Options (Unset / Set (0))
Flexi Set (No (0))
This has worked fine up until now... The user simply presents there tag to the reader and it arms and disarms on touch - no mucking about with the panel buttons etc...
The problem however is other users on the panel have started setting Area (A) on the panel, to full set all sensors
When the tag user above enters via the entry/exit route their tag can no longer disarm the alarm, as Area A is set rather than Area C which confused me at first, but I can understand based on the above why it wouldn't allow the tag to disarm the alarm.
I can fix the issue by changing the tag user's areas to A & C and changing Flexi Set to (Yes (1)) allowing them to disarm either of these set areas on touch, and arm either of them but this requires them to intervene on the panel; which I didn't really want.
I wondered whether there was anyway to allow the user to disarm both these areas but still have the panel set Area C upon tag touch?
Hopefully all that makes sense...
Thanks a lot
User Type (0)
User Areas (C)
Flexi Set (No (0))
Thanks a lot
