Dimensions:
Width: 280 cm
Depth: 28 cm
Height: 202 cm
Basematerial: Particleboard, Foil, ABS plastic
Side panel: Particleboard, Foil, Melamine foil, ABS plastic
Plinth front: Particleboard, Foil
Back: Paper board, Foil
I was looking to get a bookcase with the above measurements to muffle some sound from next door as i am currently renting and dont want the expense of floating walls / structural work till im in an owend property. As the noise isn;t bad from next door if an item of this size is filled out with books etc should that go some way to reducing noise as the room is fairly hollow at the moment. I was also wondering if there is a type of proofing i could fit to the rear of the bookcase or would this just cause the sound to bounce back off the wall. The fact that the rear of the bookcase is paperboard/foil made me wonder if it would have any impact at all.
The other option for £100 more is
Basematerial: Particleboard, Oak veneer, Paper, Clear acrylic lacquer
Back: Fibreboard
Thanks in advance[/i]
Width: 280 cm
Depth: 28 cm
Height: 202 cm
Back: Fibreboard
