I have a Vaillant wall-mounted 418 ECO TECH PLUS Boiler. Can anyone tell me whether it would use more or less gas if run on hot water only 24/7 with the max' temp' controlled by the thermostat on the hot water tank (set at 60C) , or whether less gas would be used if the programmer is set so that the boiler is OFF overnight for a period of 7 hours.
This is assuming there is a constant use and run off of hot water during the day.
Thank you.
Thank you.
