Hi I was wondering if anyone can point me in the right direction about whether you think I need to change my boiler diverter valve or not.
I have a tank based hot water, heating system. The diverter valve that I have is Honeywell V4073A1039. The central heating works perfectly fine when switched on but I only get partially hot water. I have tried varying the hot water tank thermostat but same result.
The flick switch on the diverter valve seems loose which potentially means that it is stuck in one position, but if that is the case then why do I get partially hot water and not completely cold?
If someone can advise whether there is a way this can be fixed then that will be much appreciated
