Hiya, I have a shed I need to wire up and have read through many many posts and think I'm almost there on everything I need and have to do.
I plan to run 6mm 3 core swa from the shed to back wall of house where I will terminate to a ip66 box. I plan to run the tail of the cores through the wall and junction box to some 6mm t&e which will run to the main consumer unit.
My question I'm not sure how to get the earth from the armour into the box whilst keeping it water tight. I did see the wiska box with earth connector thing but can't see anywhere that sells them for the size box I will need? At the risk of sounding stupid, as there is no outside connection does it have to be waterproof? It's under a open ended canopy anyway so wouldn't get wet normally.
My other question is once the wires are inside is any box ok to connect the t&e and swa tails? Was thinking a metal box with plastic front as I have these spare any looks isn't important.
