Hi All,
I'm having electric UFH installed in my flat in a few weeks & have a few questions that I was hoping you could help with -
Thanks you in advance for any help.
Cheers,
Ducky
- I have a large living room (30sq.m) & will need two heating mats of 15sq.m each. Does that mean that I will need separate thermostats for each mat, or can I use one thermostat to control both mats? THIS is the mat that I will be using
- In terms of the thermostat - Do I need to buy a thermostat that is the same brand as the mats, in which case THIS is my only option. I hope that is not the case as I wanted something a bit better, with WiFi connectivity etc. (Like THESE). Could you please confirm & let me know if there are any restrictions on the thermostat that I can buy?
- Lastly, is it worth running the mats under my sofa? It's not a flat-bottomed sofa, but it is low with a ground clearance of about 4cm. Is it pointless to run it under the sofa, or will it actually heat up the sofa if it is under it?
Cheers,
Ducky
