Question about flame sensor electrode operation
18 Apr 2007
I'm trying to figure out if the flame sensor electrode is what's causing a Ferroli Tempra 30 boiler to fire up briefly (2-3secs) but then shutdown and lockout until reset.
Everything else is calling for heat (external controls), overheat/safety thermostat, air pressure switch ok. Fan ok, pump ok.
If I disconnect the lead to the flame sensor, boiler will still fire up briefly but you can still hear the ignition operating once the flame has ignited - until boiler shuts down 2-3 secs later.
We dont give advice on gas/combustion replated matters on this forum.
DIYers are not advised to open the combustion chamber!
Its far more likely to be a circuit related problem.
Tony
