- Joined
- 9 Mar 2016
- Messages
- 13
- Reaction score
- 0
- Country
Hello
Sorry if this question is unrelated for this forum but I have a question regarding fan blades secured onto the motor shaft using lock washer …
For a normal 10" air circulator fans the lock washer or any mechanism used to secure fan blade coupling onto the motor shaft are more simple than the bigger air circulator fans. (As in the bigger one will have threaded shaft with bolt nuts etc but the smaller ones will only have lock washer or something else that's simple).
Some have the self locking starlock washer placed on the half flat sided motor shaft (D shaped shaft) as shown on the picture I've attached and others have other mechanism for securing the fan blade over the motor shaft.
My question is how can the use of a circlip lock washer (e.g. e-clips, c-clips etc) that's placed on the motor shaft (behind the fan blade coupler) secure it from coming/sliding off of the motor shaft? I can't see how a lock washer placed behind the fan blade housing will keep it from coming off the motor shaft? as it doesn't grip onto the fan blade anyway.
Sorry if my question is vague but I don't know how to word it properly. I hope you get the gist of my question.
