Hi guys
Looking for some advice on the following please.
For context, it's a 7 degree timber lean to roof on conservatory. 6x2 wall plate and 6x2 joists spanning 3.06m.
Wall end using a ledge plate and joist hangers.
Conservatory end bird mouthing on top of a 3x2 ring beam and 90degree angle bracket/nail gun on to the beam
1) does the ledger plate that fastens to the wall need bedding with mortar behind or am I getting mixed up without something else?
2) what would be the minimum anchor sleeve spacing be? Was thinking of just going between each joist tbh. So would use 11x 120mm anchors across 4.8m
3) are Noggins required or will the hangers and birds mouth be sufficient? I read Noggins are needed at any joist where the osb will land so left side, right side and middle two in this case.... or will they all need Noggins?
And can the Noggins be standard timber 3x2 as I don't want them same 6x2 to allow air flow across the roof.
