Good evening,
The previous owner of my house decided that it would be useful to have the cold water feed routed under the front garden and in through the house, under the stairs and into the kitchen via the external wall.
The pipe is blue alkathene and it hadn't been insulated at all. I've just had the internal plaster of the outer wall (end terraced house) redone as damp cavity wall insulation had caused penetrating damp a couple of years ago. This was removed by the installers and I had some vents added to the outer skin of the house to allow the cavity to breathe.
In addition to this, the blue alkathene pipe condensates at times and I'd like to ask for some advice on the best way of insulating the pipe. It had previously been covered with some trunking (apart from under the stairs) but now that I've had the wall replastered I'd like to prevent the pipe from condensating and causing any issues for the new plaster.
Here are some pictures of the pipe:
https://ibb.co/bNz5kb0
https://ibb.co/Csj6GKQ
