Not been doing oil for long so forgive me if im asking a obvious question!
Visited a breakdonw today-boiler going into lockout without firing up.-oil pressure is ok,geting sparks at electrodes-but only getting 60v going to solenoid-so i thought it must be photocell.With photocell wires disconnected it gives a resistance reading of zero in darkness and a reading when exposed to light so seems ok,the terminal blocks(number 1 and 2) are showing a resistance reading with nothing connected to them,when i remove the terminal block from number 1(hence no resistance detected by control box) the boiler fires up b4 obviously locking out due to no photocell connected.
My question is........should the resistance reading between terminal 1 and 2 read zero when nothing is connected to them? If this is the case then its cleary the terminal block gone faulty but looking at it the screws should go into plastic so how can there be a reading between the them?
Any advice will be welcome incase in barking up the wrong tree!
