Hi fellas,
I'm trying to plan out the drains for my garage and I'm looking for a bit of help. My house was built in the 70's and I'm 99% certain it has a combined drain/storm water pipe run. My reason behind thinking this is that there's only one manhole and under the cover only one inspection area. I also found some backed up waste at the bottom of the rowan pipe outlet (floor wipes etc) that matches what caused a blockage originating from the soil stack.
This drain runs down the east side of the house going south/north. My garage is going to be built on the west side of the house so I'll have two rowan pipes that will need to be connected into the existing drain at north/south ends of the garage.
As the runs back to the main drain are only rain water (and perhaps a drain from a sink in the garage) can you get away without inspection/rodding points? Or even less of them? Are there no limits on what angle the pipes can enter the existing pipes? In theory only water will be able to enter the system as the rowan pipes will be fitted with those rubber bungs to ensure a seal at ground level.
Can anyone point me towards some info on the subject?
Any help is most appreciated
Also I can stick a sketch up tomorrow if required when I'm at my autocad machine!
