hi,
has anyone tried these?
i'm thinking of using them in wall insulation however the mind boggles when coming to U-value and r-values and the like.
currently i'm looking at a dry lined wall.
the brick will have a DPM and 3x2 battens. then with 9.5 foil backed plasterboard(9.5mm was all wickes did.i'm looking at using 12.5mm std plasterboard to go over top left over from a previous project)
i've been looking at 50mm or 65mm (and poss 30mm high density) insulation slabs.
the thing is my false roof i'm putting in will most likely have 170mm wickes rockwool. in that case will i need to go to far with the wall insulation?
also surely these slabs provide more thermal insulation than stuff like rockwool, right?
i've looked at celotex and kinspan but that is going to go well beyond budget.
any thoughts...i guessing its borderline on the ole building reg questions...
any feedback would be great thx.
