I have bougt 5 pet immune PIR sensors for my fitted house alarm so that the dog doesnt cause any false alarms and i will no longer need to omit half the house!
The wiring looks straight forward, i will just copy the wiring set up with the exisitng PIR's but the only difference between the two is that the new ones have an additional wiring point shown as RLED - there is a jumper on the board which you can use to select RLED off.
If i do this will i get no LED at all on the sensor all will it be powered by the alarm instead of remotely.
The new PIR's are Texecom 3D Petwise if this helps.
