I am renovating a property and will be replacing architrave on all rooms upstairs. If I have the walls re-skimmed, should I change the artchitrave and skirting first - before re-skimming - or after?
In the case of the architrave, I am thinking that if I remove the architrave first, then have it re-skimmed, the plaster will thicker when I come to fit the new architrave and it won't line up properly i.e there will be a gap between the architrave and the door frame?
Many thanks in advance,
Rich
Rich
