Hello
I have a 1950s chalet bungalow which has a simple roof construction comprising only rafters, with no other inner structural members apart from one horizontal beam each side, set into the gable ends and running the full length of the roof space.
These two beams (one each side) are positioned - unsurprisingly - half-way between the ridge board and the tops of the downstairs walls, to brace the rafters at their mid points.
It's similar to the photograph at the bottom of this page (please ignore the RSJs etc; I'm just referring to the horizontal beam near the top of the photograph):
http://www.loft-conversion-cost.co.uk/designing.html
In my case these beams effectively dictate the width of the roof bedroom as the bedroom's stud walls are positioned immediately inside these beams.
The beams don't appear to be under a great load as I can move them very slightly if I push hard against them.
If I wanted to add a dormer window, or widen the room, these beams would be in the way, so is it possible in principle to remove a section of these beams (for example, to install a dormer window), by fitting vertical struts that transfer the load from the beam's cut ends, down to the floor joists immediately below?
Or for room-widening, could these beams be removed completely by substituting their presence with vertical struts from each rafter, down to each corresponding floor joist below?
The floor joists for the roof bedroom are 6" x 2", if that is significant.
Thanks very much
Thanks very much
