Ive got a retro fitted Megaflow, running on a Worcester Bosch Greenstar RI gas boiler. When the Megaflow was install it appears they kept the Y Plan heating system in place, however, they have not added in a thermal cut out valve on the primary flow to the coil.
My question is, once a thermal cut out 2 port valve is added to the primary flow to the coil - should there also be an automatic bypass installed between the hot side of the 3port valve, and the new 2 port valve, linking to the return to the boiler? My thinking is that in the event of a fault and the T&P valve not working, and the thermal 2 port valve being called into operation, should there be a bypass to enable the water to continue around the system, just avoiding the cylinder?
Thanks for your thoughts in advance.
