Hi all,
I'm going to put mains and lights in my shed (its actually a kind of 'lean-to' that shares one of its walls with the house wall.
My plan (after some advice on this great forum) is to run 2.5mm Twin and Earth cable from a dedicated breaker (20A) in the distribution board (RCD protected). Then put a consumer unit in the shed and feed the lights from a 3A breaker and the sockets from a 16A breaker.
Do I need to run a separate 6mm Earth from the distribution board to the CU or will the Earth in my 2.5mm mains cable suffice ?
All the conduit and boxes will be surface mounted and made of plastic so won't need bonding.
Advice would be appreciated.
Many thanks
John
Many thanks
John
