- Joined
- 13 Dec 2019
- Messages
- 81
- Reaction score
- 0
- Country
I’m a mixing newbie and doing a shed base (10x8) all by myself. I’m a fit and strong guy, but still know I’m in for some body aches after. I had some quick fire questions it would be good if someone could answer pls:
· For mixing order. I understand best solution is to add ½ water, ½ ballast, all cement, ¼ water, ½ ballast, ¼ of water. Please let me know if need correcting.
· I wanting to use a retarder to lengthen the workability time. Is this recommended? I intend to do the work when temp 10 degrees.
· Can I use concrete reinforcing fibres with a retarder? I’m not going to use rebar/grid etc.
· How best for one man band to mix? (1) Put current mix in wheelbarrow, lay down in base – and then load up the mixer again (leaving it to mix) before levelling shed base……… Or (2) do I finish the levelling process each time on the shed base before going and starting the mixing process again?
· When the day is finished, I need to clean the drum and understand I do this with water and say pebbles/gravel. What do I do with the finished slurry? Can’t put down the drain.
Thks
Thks
