The hob im fitting has 2 cables coming from it, (to cater for multiphase instalation) one of which has normal LNE strands, the other has 2 live and 2neutral strands joined together, plus an earth.
The supply to the hob is fed via 10mm t&e from a local CU, to a cooker switch to provide isolation.
Im assuming there is no issue with joining all the supply strands together within the cooker sw..?
Appreciate comment from someone who has fitted similar.
cheers
cheers
