Hi all,
The house I'm in (old victorian house) has existing sockets in the skirting board- plastic fronts sitting on metal back boxes (the metal back boxes are fairly 'flush' with the wood surface).
I've read quite a few posts on here about this and it seems that as long as there is enough room below the sockets this should be fine under various regs. I have 6cm-7cm clearance from the bottom of the socket so think this should be fine for moulded plugs. Also the wiring is grey sheathed, black and red style coloured so I assume that indicates the rewiring wasn't donkey's years ago?
Therefore I just want to change the socket front.
I've seen this question asked a few times but often without reply (probably becuase it's so obvious to you all) - but the is no (electrical/earning etc) issue with mounting metal style socket fronts (chrome/satin chrome) on these on a skirting board.
The second query, is for a 'flush' surface mounted style (I've seen some screwless crabtree ones) how far back does the metal back box need to be? The couple that I have checked seem to have the edge lined up with the surface of the wood and I'm not sure if it actually needs to be sunk back a bit further?
Just trying to guage my options so can have a rough idea of cost in terms of material options and work need to sort!
Ta for help!
Ta for help!
