Quick Q: extending flexible tap tails: best practice?
11 Dec 2014
Manchester
Just a quick yes/no question folks.
Fitted a new monobloc mixer in the kitchen. It came with 300mm flexi hoses.
I needed 500mm to reach the isolator valves.
While you can get flexis in a dizzying array of lengths, monobloc ones are only stocked locally in 300mm.
So I bought a pair of 300mm flexis (with 1/2 BSP nuts and black washers on each end) and joined them to the 300mm monobloc flexis using a ball ISO valve (like this). I just removed the nut and olive and screwed them together.
Pretty cheap and gives me more than enough length (around 610mm).
Is there anything wrong with doing this? Am I leaving myself open to leaks since I've introduced two more threaded joints?
You shouldn't use a nut/olive compression fitting to connect onto something designed for a washer as the chamfer will cut through the washer and leak. Much better to use a Male Iron and a short piece of pipe.
You can get the flexi's in different lengths, but you need to know the M size of the tap end.
Yup, As Dan suggest, replaced a few of these where the flexi tail was tightened onto an ISO valve and the valve seat has cut the rubber washer over time, ending up in a leak.
Copper tails from your iso valves then the 15mm>1/2" male iron couplers for the flexi's to connect to.
