HI,
New extension shell complete, internal walls are cncrete 7n blocks. Inended to dot and dab with PB then skim coat.
I am going to sink back boxes for the electrician to save a bit of money but I am unsure how much i need to sink them by and what he will do with the cable.
Was assuming allow about 10mm for dabs and then thickness of pb and then sink the boxes by depth of box minus pb and 10mm for dabs? Would that be right or should I go a bit deeper just in case?
Also interested in what is standard practice for the professionals regarding running of the cables to these, will they just be attached to the wall and run in the gap behind the pb (i.e. the gap that the dabs create. I am going to pb myself so can put it on after the spark has done the fixing if that's better.
What would the pro's on here usually do? Its only single storey extension. I realize conduit may allow cables to be pulled through later? but if possible want to avoid as much chasing as possible as the extension breaks into existing house and dust goes everywhere.
Thanks in advance.
Thanks in advance.
