i have an existing cold water feed to the original toilet which is now being replaced with a standard push button close coupled one.
The old cold water pipe doesn't quite fit to the new toilet as the new toilet sits a lot lower than the first. Was thinking of a flexible hose to connect from the existing pipe after the isolation valve on the supply.
question: which size am i after as i am ordering from screwfix now, do I need 15mm x 1/2inch x 10mm (bore) OR 15mm x 3/4inch x 10mm bore???? I'm sure about the 15mm part, but not too certain which size nut connects to the actual inlet valve inside the cistern itself...
cheers
cheers
