Is it possible for the phase angles in a three phase supply to be wrong?. A logging instrument is reporting that the angles between the current waveforms (it does not seem to provide those for the voltage waveforms - or at least I've not worked out what key to press yet) are R-Y 120 ish degrees, Y-B = 165 Degrees, b-R = 75 degrees.
Something in the back of my mind suggests that reverse polarity on a primary winding shifts by 30 Degrees? and the figures are probably a little off what you'd expect because these are the current waveforms and the PF isn't that great
If this is so, what P-P voltages would one expect to see, I didn't think to measure them at the time, but will be back there
Many thanks
Many thanks
