I'm laying my lawn tomorrow and have one question that needs answering.
My front garden is 5 meters long 6 metres wide at the top and 4 metres wide at the bottom. The width, top and bottom is 90 degrees to the right hand length, the left hand side of the length runs on a curve from top to bottom. Still with me ??
What i need to know is the best method to lay, i was told by a gardener to lay it horizontally and cut on the curves, Another gardener said to run the turf around the edges to make a "frame" and then to fill in running horizontally.
The latter makes sense when it comes to having a strong border with no thin pieces but cutting to fit the frame could be tricky.
Plus if i lay it horizontally the grass will lie the wrong way as i want the lawn to look longer by laying vertically, from front of house up to footpath as opposed to from drive to neighbours drive ?
Any ideas, tips or suggestions.
Regards
Regards
