when routing fire doors, for the 10 mm intumescent door seals strip to sit in what size router bit do you use for a tight fit thanks in advance regards david
if you have a lot to do get a dedicated intumescent strip cutting bit, they are far quicker and there is no risk of the bit wandering or cutting over width.
