Have the Decorators in & they have noticed that my Rad in the Main Bedroom is leaking...
Looks like the leak is coming before the Valve, running down the Pipe & into a hole in the Skirting Board, which is why I haven't noticed it!!!!!!
Tried closing both Valves, which made it worse....Have got an Emergency Plumber coming out Mon, just in case the System needs draining & the Olive/Valve replacing.....
If it gets any worse, then they will come out straightaway.....
Just asking, from experience, would it be worth trying to "tighten" the Nut a bit more to see if it seals the leak from the Nut/Olive, or Could I potentially make it worse?.....
I've just had the Boiler changed & the Boiler Guy gave my system a Flush & put inhibiter in...So If the System does need draining again will I need to buy some more inhibitor & put it in....? Will that effect any Warranty on the Boiler.....
