Quick reply needed: bath tap pressure query
20 Apr 2005
Hello
Hate to be so demanding, but I am about to order an entire bathroom suite, and I need to pin down the tap options sharpish to book a delivery slot.
We live in a bungalow. We have a cold water tank in the loft, and a hot water cylinder at ground-floor level.
Am I correct to assume that this will not give us a pressure rating to boast of? The bath tap we like most is a tap/shower fitment mixer, but has a recommended minimum pressure rating of 1.0 bar.
I don't know how to measure pressure, but am I right in thinking that this tap is only suitable in a high-pressure environment, and is unlikely to be suitable in a set-up like ours?
And, as an aside, just what kind of set-up is required to give a 1.0-bar tap pressure?
I think one bar is approx 10m head if memory still working :rolleyes: In your case this would mean you will have appox 0.3 bar at hot taps :rolleyes:
You need to make sure you buy low pressure taps. A lot of these fancy looking new ones are foreign rubbish that are designed only to work on mains pressure systems, eg,megaflo's etc
It's not cheap stuff. Well, I hope it's not --- it's Kohler.
But there is a similar tap without the shower attachment with a recommended rating of 0.2 bar, so I think I'll have to go with that.
