Is there a quick and easy way of reducing flow to a tap without it making a horrid noise? I know the bad way of doing this is to adjust the valve leading into the tap, but I was wondering if there are any other mechanisms that are cheap and easy to install e.g. a plastic/metal insert that can go into a valve or fitting which reduces the diameter of the opening and thus helps reduce the flow to the outlet?
My tap does not support such a device on the aerator, and I really only want to reduce flow on the cold side.
If you have any ideas I would appreciate it.
Jon
Jon
