Quooker boiling tap issue
26 Jan 2013
Cambridgeshire
Hi, any ideas why a Quooker boiling tap might run briefly and then suddenly stop/shut off? It has started doing this since a service and while it does produce boiling water it doesn’t produce much at all and then just stops. After leaving for a while you can then repeat with the same result.
There's a blockage .....get the chap that serviced it back, he shouldn't charge any additional labour ....you may have to pay for a part.
Should have stated that I did the service (via Quooker self-service kit). I’ll check components for a blockage. Strangely the problem also started after a power cut but I assume that’s just a coincidence? If is down to a blockage then I don’t understand why it runs at all. Wouldn’t it either not run at all or run at a consistently reduced flow rate (if partially blocked).
