Quooker inlet combination valve replacement
6 Jul 2020
Hi all, whilst moving i've managed to misplace the inlet combination valve for my old Quooker. Does it have to be a direct manufacturer replacement or can another type of pressure release valve/parts be used safely?
The Quooker unit holds water under pressure at about 110 degrees. This makes it potentially a bomb loaded with super heated water/steam sitting about groin level. Get the correct inlet valve from the manufacturer. Not worth risking anything else.
Thank you Elkato, I thought that might be the case but just thought i'd check. Much appreciated.
