3 bed detatched house set well back from the road with a TNS supply. Adiabatic tells me 10mm main earth ok. there is a detached garage at the front of the property near to the drive entrance about 20 metre away and a few years ago a gas supply was installed using the detached garage for the meter and a gas supply buried for 20 metres entering the house for its various needs. The garage is supplied electrically from the main cu via a buried 3 core 6mm submain. There is no main bonding anywhere. I will bond the water supply and i will bond the gas supply in the garage. my question is, do i need to bond the gas as it enters the house?even though i will bond as it enters the garage The earth is exported to the garage via 6mm swa conductor and proven armour conductor.
Any advice would be appreciated.
