Is that ........Re: gutter (at) the back of the house.- supply and fit new drain pipe. 2 new gas cowls ? Gas Safe work ? Refix lead.Does anybody else think this sounds awfully cheap?
Re gutter the back of the house. Supply and fit new drain pipe.
Supply and fit 2 new gas cowls.
Refix lead on chimney stack and on front porch £395
Hi Nige, that is correct.Is that ........Re: gutter (at) the back of the house.- supply and fit new drain pipe. 2 new gas cowls ? Gas Safe work ? Refix lead.
Not had others yet. I just know somebody who paid hundreds just to have chimney re flashed.How much are the other quotes? Sometimes 'cheap' is very expensive.
Easy job? How come it needs re fixing ?They re quoting to "re-fix" the lead which might be a fairly easy job.
It's starting to come away from the chimneyEasy job? How come it needs re fixing ?
obviously not that easy then... otherwise it would still be in placeNo idea, I haven't seen it.
