Hi, I previously had 2 cold rads and after some DIY balancing one is now working fine but the remaing one is still cold. I have had the cold one on, on it's own and it heats up fine so it is not a bleeding problem.
My question is by further balancing experimentaion should the cold one pick up? The inflow pipe up to rad is hot. Is there a minimum amount the lockshield valve can be closed on other rads without causing problems as I have adjusted a number and they are still hot but may have to do close more...
