I live in a Victorian 3 story house on the sea front in N Ireland. I want to make the loft a usable space for making a trainset. The loft is already insulated in the rafters and plaster boarded. I have a pressurised system do a high rad is no prob, but I was intending to have a master gate valve in the room below so I can easily turn on and off, as well as a TRV on the rad. But someone mentioned to do away with the gate valve dn just keep the TRV as in winter, if the gate valve is closed and the loft is not used, it may risk freezing. My worry is, with a TRV, in winter, with the East wind blowing on shore, it'll be on all the time even at the lowest setting. We have a rear wing loft which used to contain the rad header tank, and it had no rafter insulation - there was never a problem with freezing pipes.
Any advice - is there a norm - I'd basically be creating an attic conversion but without windows, I can't see it being a problem??
