Hello All,
I have recently moved a radiator and now the rad will not get hot. I had to run some new plastic barrier pipe for this and i think i have an air lock stuck in the pipe as radiator bleeds ok. I have tried turning off all other radiators and uped speed of pump but no joy.....only left it like this for a couple of mins as one valve on rad was getting really hot but no flow through rad.
I was going to try the mains water and hose trick to see if this would work and was wondering:-
1 .do i turn all other radiators off before doing this including ones without trv?
2. do i rsk damaging anythink by doing this?
3. Can i do this to both flow and return pipes or just return?
Heating is open system with header tank and is all plastic barrier pipe with 5 point manifolds branching off to radiators...
Hope this makes sense and thanks in advance..
cheers
Trevor
cheers
Trevor
