We've recently had our CH system changed from a back boiler to a modern condensing boiler (with an unvented cylinder for the HW).
The existing pipework for the radiators is apparently a single pipe system - there are flow and return pipes going to the boiler, but they then deviate into different directions.
We had a load of building work done at our house, and every room was plastered. When the radiator was put back on, we replaced all the valves with Bulldog TRVs.
So, every radiator warms up except for one, in one of the bedrooms. I suspect this is the first radiator on the loop, if that makes any difference. We've opened the lockshield fully, doesn't make any difference. If we bleed the rad and let the water run out of it, the rad starts to warm up, but cools down again as soon as we close the bleed valve.
A plumber I asked seems to think the TRV and lockshield might be the wrong way round - the water seems to come in at the lockshield and out of the TRV (which I thought was normal?)
Any ideas?
<edit>
Btw, we didn't live in this house before the building work or boiler install were done, so no idea if this radiator got warm on the old system.
Any ideas?
<edit>
