Rad question
19 Aug 2010
Luton
Hi all,
I had a type 11 rad in a room but have done the calc and the room needs 6545 BTU. I wanna fit this radiator but my problem is the space from wall to front of rad. There is a door which would foul if 'wall to face' was 115mm but would be OK if that measurement was 100mm.
Is it the case (Ihope) that these are 'either/or' measurements selected by rotating the wall hanging bracket?
It looks like there’s a 15mm difference on both the wall to face and wall to pipe centre measurements so I’d say that was dependant on which way round you fitted the wall brackets. A quick phone call to the supplier should confirm this.
If these are Prorad branded radiators then a look on their website will allow you to download their leaflet which has diagrams showing all the dimensions of their radiators and their mounting brackets.
I've attached this leaflet.
  • Prorad sizes.pdf
