Rad replaced in pressurised system remains cold
28 Nov 2005
I'm sure this is something silly and I'll kick myself(promise) when I find the answer.
I have replaced a leaking radiator in the bedroom. It was a twin with single convector and I replaced it with a double with double convector. Not a problem in itself (I hope).
I put the bleed valve on the same side as the old one but despite bleeding it till it makes my wife wet (she a good bleeder), the rad remains cold. The feed pipe on the left is hot and the feed pipe on the right is cold (bleed nipple side). Is it a stuck valve? Any suggestions...
BTW the boiler is a Suprima 60 and its a closed system that normally operates at 1 bar....
help please... :cry:
If you look at some of the other threads describing similar problems you'll get some ideas.
are the valves either side open?
failing that hit it. hard. :LOL:
it wont cure it, but youll feel better.
Thanks for your help.... :D
Apparently it was sludge in the system blocking the return valve....
I closed off all the other rads and turned the CH pump up to 3.
I then whacked the valve on the return end with the handle of a screwdriver a dozen times and it seemed to do the trick...
The rad is now hot at the bottom as well as the top... :p
I'm suprised it was sludge bearing in mind its a new rad so next job will be a drain down and sludge removal (how do I do that?)
Thanks again all
Apologies if this is a thicko question....
I have seen additives that remove sludge, does this miracle cure dissolve it to now't or is it full of false promises like Mr Muscle oven cleaner ... :eek:
TIA....
