Rad tap won't turn off
19 May 2005
Sussex
I want to take a rad off and leave the taps turned off without draining the system so I can leave the system on while the rad gets sand blasted, only one of the tap won't stop turning.
There doesn't seem to be enough exposed pipe to freeze; its a non-standard size I can't find a capnut for; and the floor is tiled concrete so no other pipe I can access.
Is the only option to drain the system and replace the tap?
Cheers!
:eek:
