I am considering installing a radial circuit from the CU on a 20a MCB to the attic to provide plug sockets in that area for TV boosters. What is the process please?
What is the anticipated load of the boosters ?
Why have you chosen a 20A MCB ?
What is the length of circuit ?
What type of earthing system do you have ?
Will the cable be buried anywhere ?
Is there existing RCD protection at the CU ?
Is your earthing and main protective bonding up to current requirements ?
Are you aware of the notification requirements ?
Can you not feed the boosters from the lighting circuit ?
it would be much more sensible to break into the lighting circuit and add a 3amp FCU, to stop someone later on coming along and plugging a 2kw convection heater into your 6amp lighting circuit.
I would also try to avoid breaking into an existing cable and find a JB / rose you can take a twin and earth from
