Got a customer whose kitchen has six down lighters. The down lighters are 230v with the power taken through a switch and then linked via a switch live loop - Only two of the downlighters are immediately accessible and these two are not working. The other four are working but are inaccessible (sods law) without removing floorboards or chipping away at the artexed and painted ceiling, which the customer has declined.
Checked bulbs - they work.
Each of the dead down lighters has two T&E cables attached for the switch live loop, neutral loop and cpc which makes me believe that they are part of the middle of the circuit.
While the other lights are working a voltage test at the two dead lights reveals zero voltage across line,neutral and cpc. If these are mid point lights then how can the other lights after them work?
Has the electrician wired a radial network using JBs?
where did those stars come from? Mods must be quick except there is one star too many - so they can't spell sods.
