- Joined
- 12 Sep 2007
- Messages
- 72
- Reaction score
- 0
- Country
I have a circuit which is running of a 15A Wylex fuse wire breaker.
From the CU it is ran in a radial, single wire leaving fuse box. However when it reaches the converted loft it enters a junction box and then all my sockets are wired as a ring into this junction box?
Can this be left as it is or should I remove the last leg of the circuit, probably crimp connect the radial circuit and therefore remove the junction box?
Also, with a radial circuit is it satisfactory to spur of a spur, can you realistically add more sockets from other sockets etc. as long as you require.
laymen terms, you have 5 sockets wired on a radial, can i add a "spur" on the 3rd socket and then spur from this again?
as long as it is all on the 15A breaker, wired in 2.5mm, nothing is going to be wrong with this?
Thanks for your answers
