Hi all,
Sorry for what is a very novice question but I've been reading through loads of posts and can't find anything similar.
I've just bought a new house and the lounge has no lights. My challenge for the weekend (more likely next 6 months) is to put some in. The lounge currently has a light switch which operates a 10A radial circuit with 3 double sockets on it. The lounge also has two other radial circuits with one double socket on each. These are both 15A. All of the existing radial circuits are using 2.5mm T.E. cable.
My plan was as follows:
Pull the existing wiring from the switch thorugh to the upstairs floor and join the two ends with a junction box. This removes the switch from my existing radial circuit.
Then run a new length of 2.5mm T.E. between the last socket on the old switched radial and one of the other sockets on another radial circuit. Hence creating a ring. Replace the 15A and 10A MCBs on the CU with one 30A MCB and join both the ends of the ring to that. (This leaves me with a downstairs ring at 30A using 2.5mm t.E and an extra 15A radial circuit with one socket on it).
Now add a junction box to the existing 5A downstairs lighting circuit and run the lounge spur from that. Run two 1.5mm T.E cables back to the switch for the double dimmer switch the mrs. wants. (the lounge is going to have two ceiling lights in it)
Now the question is does this all sound like it's the right way to go about things and does it meet all the regulations? I'm assuming I'm not allowed to simply upgrade the MCB on the old switched lighting circuit and use it for normal power (TV, video etc.) hence the first bit. Please tell me if I'm making things way too complicated.
Thanks in advance
Thanks in advance
