- Joined
- 1 Oct 2008
- Messages
- 11
- Reaction score
- 0
- Country
I have just moved into a new house, switched the central heating on and it not working properly.
Radiators
We have 7 upstairs radiators and 9 radiators downstairs.
All radiators are fitted with TRV and Lockshield valves
We have underfloor heating one additional room
Boiler
Boiler is a Worcester Condensing Boiler Model- Z8-728 recently serviced
Rad temp dial is set to 4 out of 6
Display is reading 62 degrees
Eco light is on
Pressure is approx 1.5 bar
With the upstairs thermostat on 30C and the boiler on permanently I can not get all of the radiators hot.
If upstairs lockshields are open so the rads are hot then the downstairs will be cold.
When upstairs rads are turned down so they are warm (not hot) I can get all of the downstairs rads warm except 3.
If I switch all of the upstairs and the majority of the downstairs rads off I can get the three problem radiators hot.
But as soon as I start to introduce more than a couple of other rads into the circuit these go cold again.
I have tried to balance these by touch so all of the rads feel like they are at the same temperature rather than use thermocouples as I don't have any. But I have had to turn the radiators down so they are between 1/4 and 1/2 turn on at the Lockshield value.
I haven't tried to adjust them so that there is a 12C difference between input and output as I think this will take too much heat out of the water flow upstairs and will lead to cold rads downstairs - plus I don't have thermcouples.
I believe the pump is set to 3 and is working.
I have tried to increase the pressure in the system further but the input water feed won't take the pressure higher than 1.5.
What do you suggest next?
Increase the temp further and try and rebalance?
Invest in a set of thermocouples and set each rad to 12C each (I am very sceptical that this will work)
Any advice appreciated
Phil
When all other rads are switched off I can get these very warm
Radiators
Boiler
Eco light is on
Phil
